Priority tag for jobs invoked via notification service
  • Apr 4, 2016 3:28 PM UTC
  • 96 views
Is there a mechanism to set the priority of a job in FME Server that is triggered through the notification service via a message to a topic.
For example the jobsubmitter service allows the passing of a tm_priority tag as a querystring parameter and I'm wondering if this is also possible via the message content on a topic to trigger jobs invoked via the notification service to run with variable priorities.
stalknecht
Forum|alt.badge.img+22
  • Apr 6, 2016 6:47 AM UTC
If you create a subscription you can set the priority under the Advanced section.
sigtill
Forum|alt.badge.img+25
  • Jan 26, 2017 1:13 PM UTC
But you can not alter a subscription created from FME Desktop?
