Prerequisites for Automations
  • Jan 23, 2025 4:28 PM UTC
  • 80 views
mbaumgartner
Hello
What are the prerequisites to be able to run Automation on a FME Flow instance?
When I try to build and test/run an automation I keep getting an error:
Unable to assemble automation. There was an issue with component "Workspace". Subscriber configuration does not exist.
It does not really matter what I add as action in the Automation. I keep getting this similar error.
The FME Flow I am using is running in a Kubernetes environment on an Azure cloud with one Engine using version 2024.1.
In the end my question is is it the set up that does not allow Automatons or is there possibly something missing in my installation? Or any other reason that I can not see?
Unfortunately I was unable to find any thing in the documentation or any where that could explain this
  • Jan 24, 2025 7:13 AM UTC
Sounds like a fairly fundamental problem somewhere, perhaps linked to the installation and/or configuration.
Have you looked in the server logs for errors or warnings?
