Need connected line attribute object id in new created field of same shapefile attribute table
  • Sep 28, 2021 5:11 AM UTC
  • 56 views
actualabhijeet
Need connected line attribute 'object id' in new created field of same shapefile attribute table. In Flow of direction with connected line feature attribute id in previous line feature - new created field.
Check image snapshot and example excel snapshot for the same attached below for more better understanding.
Image01Image02 Please provide help or problem solution for this situation.
actualabhijeet
I am trying this in ArcGIS too for something like can be done. Still no luck.
danilo_fme
Forum|alt.badge.img+58
  • Sep 28, 2021 8:03 AM UTC
Maybe connect the linhes with linecombiner and create a list of attributes.
Can you share the example of data?​
