JSON from email publication invalid
  • Jan 28, 2022 9:24 AM UTC
  • 97 views
djmcdermott
Forum|alt.badge.img+7
Hello,
I have set up a IMAP publisher to poll one of our inboxes. The idea is for it to trigger a workbench to download and process data when our supplier informs us of an update. When I send a test email which is either blank for in plain text it works, but the supplier emails are HTML and the JSON in the Topic is invalid. The part of the JSON that is invalid is in the imap_publisher_content{0} section. This is the HTML message which I think it treats and JSON so fails when it’s expecting a : or }. Please can you help?
Thanks,
David
Best answer by markwatsafe
Hi @Mark Warren​ I have attached the JSON that is dropped in the Topic Monitoring. I have removed sensitive data. I think what’s happening is FME is escaping HTML characters but not CSS. For instance in this element:
<span style=\\"font-size:12.0pt;font-family:"Source Sans Pro Light",sans-serif\\">
It escapes the “ but then see’s the ; and thinks its part of the JSON.
Thanks
Thanks for sharing the data! I've found that the errors are happening at the double-quotes (") –specifically the font-family style attributes (i.e: "Arial", "Segoe UI", "Source Sans Pro Light")–since JSON key values need to have "s escaped or else it'll be considered invalid. I used some StringReplacers to remove the double quotes from those 3 font families, and FME was able to parse the JSON after, like this:
Screen Shot 2022-02-03 at 12.07.22 PM
I'm looking into this with your partner 1Spatial so we'll investigate further and share more info through the support case.
UPDATE: Using the Email Trigger in Automations and the Email Body output key avoids the issue.
markwatsafe
Forum|alt.badge.img+11
Hi @djmcdermott​ , could you please share a snippet or screenshot of the errors you're getting in the job? I'm wondering if the issue is occurring at a JSON-parsing transformer and something is slightly off with a JSON query. We should be able to handle various content types in the imap_publisher_content{0} section like plain text and HTML since it's still "wrapped" in the JSON payload.
djmcdermott
  • Feb 3, 2022 10:12 AM UTC
Thanks
markwatsafe
  • Feb 3, 2022 8:08 PM UTC
Thanks
