Issue with SchemaScanner Misinterpreting ID Field Data Type
  • Mar 19, 2025 1:10 PM UTC
  • 7 replies
  • 198 views
jugoslaviaa
I have an ID field that is correctly read by FME as varchar(22) when writing using the Feature Writer.
However, before that, I use the SchemaScanner, and it incorrectly detects the data type as fme_real64. As a result, the original value is eventually written in scientific notation, like 2.2072213393213062e+21, instead of preserving the original string format.
Is there a way to ensure that SchemaScanner correctly detects the field as varchar(22) to prevent this issue? Any suggestions would be appreciated!
nielsgerrits
Forum|alt.badge.img+67
I think adding a space to OBJ_ID as a suffix using an AttributeCreator before the SchemaScanner and remove this space afte the SchemaScanner using an AttributeTrimmer should work. It is hacky and a workaround, but I think it does what you need.
jugoslaviaa
  • Mar 19, 2025 1:34 PM UTC
A space did not work but adding # worked however fme_varchar(23) of course instead fme_varchar(22). Do you know why SchemaScanner messes up  like this?
nielsgerrits
It tries to interpret the data type, but why this results in a scientific notation, I do not know. What data format are you writing to?
As to the char 22 vs char 23, you probably can solve this by inserting a dummy feature with a dummy 22 character string as id in the stream before the SchemaScanner and remove this feature after the SchemaScanner. This is probably more performance efficient as well.
Forum|alt.badge.img+54
  • Mar 19, 2025 1:51 PM UTC
Can you not set the type explicitly in an AttributeManager prior to the schemascanner?
jugoslaviaa
  • Mar 19, 2025 2:02 PM UTC
​@ebygomm What do you mean explicitly? When I add AttributeManager, it immediately recognizes varchar(22) and SchemaScanner still think it is fme_real64 although I added AttribiteManager
nicholass
  • Apr 2, 2025 1:04 PM UTC
​@jugoslaviaa Did you happen to sort this/ find a workaround? Getting the exact data type for my schema is very important for the validity of my data.
I also have this issue with my attribute data type going from fme_real64 to fme_int16.
jugoslaviaa
  • Apr 2, 2025 7:24 PM UTC
Unfortunately, I could not find a plausible workaround
