Importing openpyxl
  • Jul 22, 2019 6:24 AM UTC
  • 8 replies
  • 243 views
Hello All,
I am trying to import an external module named openpyxl in FME but unfortunately isn't able to setup the environment. Can anyone please help me with identifying what all is required to setup the module in FME?
Every time i try to run it inside the python shutdown script it throws the error as module doesn't exist.
stalknecht
Forum|alt.badge.img+22
  • Jul 22, 2019 9:26 AM UTC
You should use the same python version you've installed the library to.
I think the python interpreter in FME is different from the one you use for the openyxl outside FME
In the scripting part i am using Esri ArcGis Desktop(Python 2.7)
and for the translation i am using FME Python 2.7
stalknecht
  • Jul 23, 2019 5:55 AM UTC
On which version did you install the openpyxl? Does it work apart from FME?
@stalknecht 2017 FME Version. Its working inside the python shutdown script independent of the workbench operation.
stalknecht
  • Jul 23, 2019 7:52 AM UTC
Sorry, maybe I'm confused. Was it working in earlier version and you try it now in a newer version. If yes try to use the same interpreter.
I tried it for the first time in FME 2017 using the interpreters mentioned above in pics and it isn't working. I changed the interpreters also but still the issue is prevailing.
@stalknecht I am not sure how to use this link Installing python packages to FME Desktop
stalknecht
  • Jul 24, 2019 8:01 AM UTC
Here is a link on how to install and use PIP: https://www.liquidweb.com/kb/install-pip-windows/
Here is alink how to install the openpyxl:
https://openpyxl.readthedocs.io/en/stable/
