I need to install and use FME server on an Ubuntu cloud machine, on distant, via SSH command terminal. Could you please advise me about that? Thanks.
  • Jun 23, 2021 12:58 PM UTC
  • 40 views
I will make a backup from my current Windows machine, Will it be possible to restore it on that machine? Thanks.
itsmatt
Forum|alt.badge.img+48
  • Jun 24, 2021 12:15 PM UTC
The easiest way would be to probably use docker - however, if not you can follow these installation instructions:
For a silent installation here: https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Silent-Install-Linux.htm
For normal express installation here:
https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/ExpressInstallation_Linux.htm
It should no problem to restore the backup, however, I would keep the windows version running in case there are issues.
