How to stop an automation when no features are left?
gisbradokla
Forum|alt.badge.img+17
I have automations that read sql tables an read the filenames in specific tables. in order to iterate through the records the automation updates a flag (i.e. PF = 0, 1, 2, 3) The automation runs on an interval and gets the next record PF=0 and sets the flag according to how far it gets through the automation.
It’s seems like it would take quite a bit to rig a method to get the PF=0 count and corelate that to how many times the automation runs.
I am looking for suggestions on how i could determine there are no more pf=0 records and stop the automation.
Is there a transformer for Flow that will use data to stop the automation?
Probably with python (right?) non python?
danilo_fme
Forum|alt.badge.img+45
  • June 12, 2024
Hi @gisbradokla
Maybe you cna use the transformer Terminator to stop the process.
Thanks in Advance,
Danilo
gisbradokla
  • June 12, 2024
@danilo_fme  Trying to understand how to implement.
should i create another workspace and maybe have a query in it that only goes to the terminator once there is no feature that comes in? I use parameters to pass the filename through 3 different workspace as it is processed. This is the last workspace that writes the flag to 3 (complete) only if the feature makes it to here does it get written. if there is not another record with flag = 0 then there would not be a feature come into this workspace and it never runs. but there are other reasons why a feature would not come out of the previous workspace. So once the table has no values for flag that = 0 then i can terminate the automation. Do i need to write some python or something to go in the terminator? it just says terminate.
jkr_wrk
Forum|alt.badge.img+29
  • June 13, 2024
A Terminator does exactly what it says…
Terminate the process if a single feature goes in… with an error/failed process in the log.
So the logic of when to terminate is done before. Test if there are features, if not send a feature to the terminator.
Using a FeatureMerger you could set up some AND/OR/XOR/NOR situation if you need to.
I did not do much with the Automation capabilities but it sounds like the solution is more in the trigger of the automation than the workbench itself?
lifalin2016
Forum|alt.badge.img+30
  • June 18, 2024
In general, automations have very few possibilities wrt. logic and testing.
If you require logic and testing in your automation, I will suggest creating small/modular workspaces, with automation writer outputs.
Have the workspace handle the logic and testing, using published parameters as input, and automation writer ports as output.
