How to join Json (one row of data) to multiple rows in a shape file?
  • Nov 9, 2020 4:30 PM UTC
  • 130 views
Hi Everyone,
I have a Json file that i want to join to a shapefile. The json file has one row of data and i want this to be added to every row in the shapefile (the shapefile has other fields that will be updated by another shapefile). The fields I want from the JSON file are already in this shapefile.
Thanks in advance and hope that makes sense to you all
Best answer by ebygomm
You can use a FeatureMerger with an unconditional merge by setting the Requestor and the Supplier to 1
Capture
Forum|alt.badge.img+54
  • Nov 9, 2020 4:32 PM UTC
Capture
  • Nov 9, 2020 4:47 PM UTC
Capture
Hi @ebygomm​
Thank you for that - really appreciate the help. That worked for me.
