How to Establish a Connection Between FME Server and UiPath to Automate Data Extraction ?
  • Feb 8, 2025 6:22 AM UTC
  • 0 replies
  • 77 views
jokerfme
Hello ,
I would like to automate data extraction from FME Server using UiPath.
Currently, I manually select each city from FME Server and extract an Excel file containing the required data for each city ,then i place the extracted Excel file in a specific folder for the UiPath to process and perform tasks using the data , UiPath reads the IDs from the Excel file for processing.
I'm wondering if it's possible to establish a connection directly between UiPath and FME Server, perhaps using a REST API, to directly retrieve the data and work on it without manually downloading each Excel file.
Is this possible, and how can it be implemented?
Thank you in advance!
