Hi, Has anyone else had issue initiating the FMEWorkspaceRunner class in python 3.9?
  • Jul 14, 2023 12:51 PM UTC
  • 102 views
I have followed the instructions in the below post to run a workspace from python.
https://community.safe.com/s/article/run-an-fme-workspace-from-python-using-fmeworkspac
After a bit of messing about appending the relevant paths I got the fmeobjects to import but when I try to initiate the FMEWorkspaceRunner class I get 'ERRORFMEException: 1: An error has occurred' with no other details.
Extract of code below:
import os
import sys
sys.path.append(r"C:\\Program Files\\ArcGIS\\Data Interoperability for ArcGIS Pro")
sys.path.append(r"C:\\Program Files\\ArcGIS\\Data Interoperability for ArcGIS Pro\\fmeobjects\\python39")
sys.path.append(r"C:\\Program Files\\ArcGIS\\Data Interoperability for ArcGIS Pro\\python")
sys.path.append(r"C:\\Program Files\\ArcGIS\\Data Interoperability for ArcGIS Pro\\python\\python39")
os.environ['FME_HOME'] = r"C:\\Program Files\\ArcGIS\\Data Interoperability for ArcGIS Pro"
os.environ['CONDA_DLL_SEARCH_MODIFICATION_ENABLE'] = str(1)
import datetime
import arcpy
import fmebootstrap
import fmeobjects
wsRunner = fmeobjects.FMEWorkspaceRunner()
I am using the ArcGIS Data Interoperability for ArcGIS Pro
weihong
  • Apr 2, 2024 8:11 AM UTC
same problem. Have you solved it?
