generate triangles between 3D lines
zilvinas_fme
Hello,
Does anyone know how to create triangles between two 3D lines using FME tools? The triangles can also be vertical.
Best answer by takashi
The attached workspace example describes a way to create TIN surface (Mesh) from a pair of 3D lines. Assuming that the two 3D lines have the same number of vertices.
Create TIN Surface from Two 3D Lines
  • May 30, 2025
Hi ​@zilvinas_fme ,
I don't think there is a quick way to do that only with regular transformers. Probably you will have to implement some part of the process with a Python script. fmeobjects.FMETriangleStrip class could be applicable.
If you could share a sample data (two 3D lines), I would try creating a workspace example.
zilvinas_fme
  • May 30, 2025
Hi takashi,
This is a shp file, it contains all the lines between which triangles should be created. The shp file contains the attribute lin_nr, where by selecting 1, 2, 3 you can select pairs of lines.
  • May 30, 2025
zilvinas_fme
  • May 30, 2025
yes, but lines 2 and 3 and all the others don't have the same number of vertices. this is a problem for me.
