FME Server Automation error: javax.crypto.IllegalBlockSizeException: Data must not be longer than 245 bytes
  • Dec 16, 2019 10:43 AM UTC
  • 269 views
arekpierchala
Hi
I've got an error:
when trying to change and save Automation (schedule trigger + 3x sequenced workspaces)
FME Server win64, b19643
Got an error when trying to set on trigger Start Date&Time - error after Save button click.
Any suggestion?
Best answer by rylanatsafe
Hi @arekpierchala, I'm sorry that you have encountered this error. A similar posting was made by another FME Community member – they were able to identify that this error was related to a 'Password' Published Parameter in one of the Workspace actions.
I was able to get the Automation to save/run by manually overriding that password parameter within the Automation dialog
Hope that helps! If you still have issues, please use the 'Report a Problem' form on our FME Technical Support page.
rylanatsafe
Forum|alt.badge.img+14
  • Dec 23, 2019 8:00 PM UTC
jovitaatsafe
Forum|alt.badge.img+11
Hi @arekpierchala,
just wanted to update you that a recent change in the latest release of FME 2020.0.1 should have fixed this error message if you'd like to give it a try. You can find it in the downloads page here.
