FME Flow 2025 upgrade and SharePointOnlineConnector authorisation
  • Dec 23, 2025 5:05 PM UTC
  • 131 views
scottmacdonald
We recently upgraded to FME Flow 2025 but now all of our FME processes with SharePointOnlineConnectors are failing.
We have to keep going into FME Flow Connections and Parameters>Web Connections and re-authorise the Microsoft SharePointOnline connection. Is there a way to keep it authorised?
This is causing dozens of processes to fail daily because we keep having to re-authorise the connection.  I have been upgrading transformers and re-publishing the workbenches to FME Flow but wondered if this was an issue for anyone else and if there were any further suggestions.
Thanks in advance
Scott
timatsafe
Forum|alt.badge.img+8
  • Dec 24, 2025 6:25 PM UTC
Hi ​@scottmacdonald,
If you can please submit a ticket so that our team can look into this further, that would be great!
When submitting your ticket, please provide the following (if available):
- Details about the environment used (e.g. platform and OS version, FME Flow deployment, any other dependencies, etc.)
- Any relevant log files (e.g. translation logs, job logs, fmeserver.log, etc.)
scottmacdonald
  • Jan 5, 2026 10:28 AM UTC
Thanks for your reply and recommendation to submit a ticket.
Our processes were failing to connect to SharePoint however we managed to get them running again by upgrading all transformers (to FME 2025) and re-publishing the workbench to FME Flow (without ticking Emailer) and then re-authorised the SharePoint connection.
If you upgrade FME Flow then upgrade the FME Form workbenches and transformers as well and re-publish to FME Flow
Forum|alt.badge.img+54
  • Jan 5, 2026 11:50 AM UTC
What version of FME did you upgrade from?
We have a sharepoint connector in a workspace in a dev environment that was written in 2024 and it has remained running post upgrade to 2025.
