FME Flow 2025.2 - Error messages from DB not in log file when connecting to SQL Server using JDBC
  • Mar 11, 2026 3:21 PM UTC
  • 98 views
Forum|alt.badge.img+54
Testing after upgrading preprod to FME 2025.2.1 and it appears that an issue that would previously (FME Flow 2024.1) be reported back from the database, i.e. incorrect user/incorrect syntax do not appear in the log file
e.g. running a workspace with an SQLExecutor with a query with incorrect syntax in FME Form 2025.2.1 results in an error, e.g.
“java.sql.SQLException: Line 1: Incorrect syntax near '}'.”
No such message appears when running the workspace in FME Flow. The workspace fails but no SQLException is returned
This appears to be the same whether you connect with using JDBC or Microsoft SQL Server (JDBC).
Best answer by timatsafe
Hi Elizabeth,
Thank you for reporting this issue. I was able to reproduce this and have gone ahead and filed this with our development team for their review.
For your reference, the ticket number is: [FMEFLOW-27778].
  • Mar 12, 2026 6:00 PM UTC
The expected information is available in the fmeprocessmonitorengine.log but not in the job log
timatsafe
Forum|alt.badge.img+8
  • Mar 30, 2026 8:08 PM UTC
Hi Elizabeth,
