Fire Hose API to Data Processing Stream
  • Feb 25, 2026 8:44 PM UTC
  • 47 views
schulte.a
Forum|alt.badge.img+4
Hello,
So I have a platform that utilizes Fire Hose API for their data stream. My stream will have thousands of changes a second. I need to connect to this stream, clean/filter the data, and have the data end up showing on an ArcGIS webmap. What would the path be?
I am not exactly sure how I connect the firehose stream to FME (I have flow and form).
My thought process is Connect Firehose to FME (not sure how, not HTTPCaller right?) → Create data stream to process data → connect stream to GeoEvent Server → Display on Webmap?
Is my thought process accurate?
Any help is appreciated!
hkingsbury
Forum|alt.badge.img+73
  • Feb 26, 2026 6:12 PM UTC
I’ve not used this capability of FME before, but there is the ability to process big data like this. Have a look here to see if it helps to answer some of your questions
https://support.safe.com/hc/en-us/articles/25407472101005-FME-and-Stream-Processing
