Error running JobHistoryStatisticsGathering
  • Apr 26, 2024 2:57 PM UTC
  • 0 replies
  • 85 views
sunsilk11
Hi I am getting error message below when running JobHistoryStatisticsGathering in FME Flow. I am using FME Flow 2021
If I download the workspace and run it in FME Form, it works OK.
Any ideas?
2024-4-26 15:55:20 | JobHistoryReader_TestFilter (TestFactory): Feature specification `TEST_GROUP' in mapping file row `FACTORY_DEF {*} TestFactory FACTORY_NAME { JobHistoryReader_TestFilter } INPUT FEATURE_TYPE JobHistoryReader_TestFilter_INPUTLINE TEST_GROUP TEST { @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>timeFinished<closeparen>,JobHistoryReader_TestFilter) CONTAINS_REGEX <backslash>d-<backslash>d<backslash>d:<backslash>d<backslash>d ENCODED } TEST { @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>timeFinished<closeparen>,JobHistoryReader_TestFilter) CONTAINS_REGEX <backslash>d<backslash>+<backslash>d<backslash>d:<backslash>d<backslash>d ENCODED } BOOLEAN_OPERATOR OR COMPOSITE_TEST_EXPR <Unused> OUTPUT PASSED_0 FEATURE_TYPE JobHistoryReader_TestFilter_TimeFormat1 TEST_GROUP TEST { @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>timeFinished<closeparen>,JobHistoryReader_TestFilter) CONTAINS_REGEX Z<dollar> ENCODED } BOOLEAN_OPERATOR OR COMPOSITE_TEST_EXPR <Unused> OUTPUT PASSED_1 FEATURE_TYPE JobHistoryReader_TestFilter_TimeFormat2 OUTPUT FAILED FEATURE_TYPE JobHistoryReader_TestFilter_<lt>UNFILTERED<gt>' is not valid -- it has an invalid number of entries
