Error in log but translation succesful
I have a process running on FME Server 2014 SP4 win32.
It includes a notifier in the process and a notifier on failure.
I've seen now that the notifier in the process is logged with an error. This is correct because invalid credentials were provided. So in this case the on failure notifier should start when tha translation is finished but the logs says that the translation was succesful (with 16 warnings but now errors).
So the log contains an error but still says "translation was successful".
Any ideas on this?
Best answer by nic_ran
Sorry, I can't answer your question but wanted to add to this post in the hope that someone from Safe might respond....
I've seen similar behaviour. Sometimes an FME Server job will fail but report success, sometimes it will be successful but report a failure. Unfortunately, I haven't seen any discernible pattern to this behaviour so it's very hard to submit a support request without being able to reproduce the problem....
nic_ran
Forum|alt.badge.img+16
  • August 5, 2015
maarten
Participant
Forum|alt.badge.img+3
  • Participant
  • December 7, 2016
Sometimes when I run a process in FME 2016.1 (Dekstop) this is what I get at the end of the logging:
1Translation was SUCCESSFUL
2
3
4
5
6
7
8Error running translation.
9
 In these cases I do not see any error in the log and the output seems correct. When I run the process again, most times it ends without the error message at the end.
ekkischeffler
I'm getting a similar error using an Esri GDB writer in FME 64 bit (build 16674). Any ideas?
1Translation was SUCCESSFUL with 5622 warning(s) (97811 feature(s) output)
2FME Session Duration: 1 hour 12 minutes 4.0 seconds. (CPU: 482.3s user, 95.1s system)
3
4END - ProcessID: 28756, peak process memory usage: 2339864 kB, current process memory usage: 562872 kB
5
6
7
8
9
10
11
12Unhandled Exception:
13
14
15
16System.IO.FileNotFoundException: Could not load file or assembly 'GpMetadataFunctions, Version=10.3.0.0, Culture=neutral, PublicKeyToken=***' or one of its dependencies. The system cannot find the file specified.
17
18File name: 'GpMetadataFunctions, Version=10.3.0.0, Culture=neutral, PublicKeyToken=***'
19
20   at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
21
22   at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
23
24   at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
25
26   at System.Reflection.Assembly.Load(String assemblyString)
27
28   at GetManagedType(Char* _assembly, Char* _path, Char* _className)
29
30
31
32
33WRN: Assembly binding logging is turned OFF.
34
35To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
36
37Note: There is some performance penalty associated with assembly bind failure logging.
38
39To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
40
41
42
43
44
45
46
47
48
49
50Error running translation.
51
