Email notification subject
  • Sep 8, 2015 3:04 PM UTC
  • 74 views
I have set up an email notification to fire me an email when the workspace has successfuly run.  I am curious as to how I get the name of the workbench that has run to be my subject line?
Do I need to creat a seperate email notification for everyworkspace I want published?
NOTE: I do not want to use python.
Best answer by david_r
Hi
Looking at the template keywords (http://docs.safe.com/fme/2015/html/FME_Server_Documentation/Default.htm#ServerCore/Email_Templates.htm), I doesn't seem possible to include the workspace name. I think your best bet is to either use the FMEServerEmailGenerator (https://store.safe.com/transformers/fmeserveremailgenerator) or the PythonEmailer (https://store.safe.com/transformers/pythonemailer) (don't worry, you don't have to write a single line of code). Both are available on the FME Store.
David
  • Sep 8, 2015 3:09 PM UTC
Hi
David
fmelizard
Forum|alt.badge.img+22
  • Jan 5, 2016 1:55 AM UTC
This is now possible in FME Server 2016.0 The JSON that is passed contains the repository, workspace name and log URL. Like this:
{ ... "repository": "Samples", "workspace": "austinApartments.fmw", "logUrl": "http://localhost:8080/fmerest/v3/transformations/jobs/id/1/log" }
would you also be kind to tell us how to do it? (to insert the JSON srting into the e-mail subject)?
itay
Forum|alt.badge.img+19
  • Apr 27, 2017 2:50 PM UTC
My guess is that @aaronkoning means that in 2016 there are new tags, such as workspace and log that can be used the same way template keywords work
