email attach produced data/file
  • Oct 7, 2014 6:38 AM UTC
  • 49 views
Hello,
Is there a way to attach a generated textfile to an email?
in the FMEServerEmailGenerator there is the field "Attachments" but how should i point to the generated file?
thanks
  • Nov 6, 2014 11:16 AM UTC
Same question here.
How can we identify the attachement in the FMEServerEmailGenerator?
Thanks
  • Nov 13, 2014 3:01 PM UTC
You should be able to just enter a file path for example: c:\\temp\\ken.kml
 I briefly tested this today and it seemed to work fine. I'll follow up with rvgeneug in support and then post results back here when we have found the issue.
