Directory Watch in FME Flow
  • Sep 28, 2026 5:27 PM UTC
  • 75 views
vxn43
Forum|alt.badge.img+20
I am using FME Flow 2026.1.1. The trigger for the automation I created is Resource of Network Directory (updated).
I have a folder that FME Flow can read/write to/from. This is the Directory to Watch. This folder is in Resources.
Events to Watch for is set to CREATE.
The Poll Interval is 1 minutes.
The automation is supposed to trigger when a file is added to the folder. But it is not triggering. Is there something else I need to do when using this type of trigger or maybe another trigger? I tried setting the Events to Watch for to CREATE, MODIFY, DELETE and the automation still did not trigger. Any ideas on how to get a Directory Watch to trigger when a file is added to a folder?
Best answer by vxn43
Hi ​@vxn43, provided you’ve started the automation, there shouldn’t be anything else you need to do to get this working - sorry to hear you’re having issues!
How have you specified the directory path? When testing, I see the full path shown in the Directory to Watch field and not just the folder name, but this could just be a UI change between versions.
Can you also please check the trigger’s log and let me know if anything errors or warnings are shown? This is at Resources/Logs/automations/current/trigger_dirwatch.log.
I found the problem. I failed to set write permissions to the folder. I had read but did not select write. It works now.
zoe.forbes
Forum|alt.badge.img+10
  • Sep 29, 2026 5:13 PM UTC
vxn43
  • Sep 29, 2026 6:33 PM UTC
Hello Zoe, I found the error in the log file:
ERROR  | main | Treeplotter Export to Cityworks (31dfe384-e4a6-4368-a543-9fa23f18fd89) | no-event | Invalid path to watch: "\\MyServer\p_drive\FME_Workspaces\Treeplotter_Export_to_Cityworks\Treeplotter_Export_Shapefile"
In the path do I need to include the file name? Each file that is dropped into the folder will have a different name but they are all zip files. Can I use a wildcard for the file name like this?
"\\MyServer\p_drive\FME_Workspaces\Treeplotter_Export_to_Cityworks\Treeplotter_Export_Shapefile\*.zip"
vxn43
  • Sep 29, 2026 8:47 PM UTC
