Check if geopackage exists ,if exists append features if not create it and insert features
  • Mar 17, 2023 4:03 PM UTC
  • 8 replies
  • 116 views
I have a workspace that proceses a lot of features and then writes it to a geopackage but it replaces the file with new data.I want if the file exists to append the features if it does not exists to create the file.How do i do that?
nielsgerrits
Forum|alt.badge.img+67
Under parameters is a "Overwrite Existing Database" checkbox. Is that checked? Did not test this but I think if it is not checked, it should work as you want.
  • Mar 17, 2023 5:10 PM UTC
if i uncheck it, it duplicated the data inside if the data is the same
  • Mar 17, 2023 7:19 PM UTC
evieatsafe
Forum|alt.badge.img+28
  • Mar 20, 2023 10:49 PM UTC
Hi @elcontador​ I think ChangeDetector is what you are looking for, you can even have separate writers for different ChangeDetector output ports (one for appending features if it exists, one for creating it and insert features if not). Check out this article: Change Detection
  • Mar 21, 2023 5:45 PM UTC
I have 2 writers that both write geopackage using an attribute , i want to check the next time i use the transformer if the geopackage is writteen with that atrribute , if it is , i need it to check against it for the new features. if the fieatures are in the packages and there are no new changes to it , leave it as it , else modifiy them.Can i share the workbench here?
evieatsafe
  • Mar 22, 2023 11:43 PM UTC
You most certainly can share your workbench here! Sounds like maybe a Tester transformer with the selected attribute to test, and if it passes then use a ChangeDetector. Hope that helps.
  • Mar 23, 2023 7:03 AM UTC
As you can see , i have 2 writers that fan out the features based of an attribute.
I want before that to check if i have a geopackage with that name in the folder to check if the features are in the geopackage if yes , update them , if no insert them
if the geopackage does not exist, create it
  • Mar 23, 2023 4:44 PM UTC
I have answered without using reply.,its below
