Automations Writer - multiple child jobs run against a single engine
Forum|alt.badge.img+32
If there is an automation where a workspace with an automations writer, triggers a child workspace a number of times is it possible to restrict those jobs to run on the same engine without the use of a queue?
I want all child jobs triggered from the writer to run on the same engine as each other for a single automation run, but i don’t necessarily want to say that jobs can only be run on a single engine, as would be the case if I set up a queue.
hkingsbury
Forum|alt.badge.img+53
  • March 9, 2025
Sounds like a good idea to submit for development consideration!
mattmatsafe
Forum|alt.badge.img+13
Hi ​@ebygomm, there isn’t a way to do this at the moment. As mentioned, you can submit an idea for the product team to review: https://community.safe.com/ideas
If you do submit an idea, please share the reason why you need to do this and why queue control doesn’t meet the current need.
https://docs.safe.com/fme/html/FME-Flow/WebUI/Queue-Control.htm
Thanks!
