Automation workflow sharing
  • Nov 2, 2023 8:20 AM UTC
  • 50 views
zaneta.mark
Is it possible to download Automation workflow/save it to a file, so that it can be easily transferred to another FME Server/Flow?
  • Nov 2, 2023 8:39 AM UTC
You can use Projects in FME Flow for this, it was made exactly for these types of scenarios:
https://docs.safe.com/fme/html/FME-Flow/WebUI/Projects.htm
zaneta.mark
  • Nov 2, 2023 8:53 AM UTC
Thank you, that is very helpful! Maybe it would be worth to add that hint in documentation: https://docs.safe.com/fme/html/FME-Flow/WebUI/Automations-General/Automations.htm ?
