Automation Parameters are Resetting
  • Nov 1, 2023 2:51 PM UTC
  • 28 replies
  • 1429 views
Show first post
_jacques_
Forum|alt.badge.img+19
  • Mar 18, 2026 9:45 AM UTC
​@zoe.forbes Thanks for the update. I found out that in our case with the empty drop-down menu it was probably a display related issue, as the correct values showed if I opened the ‘Text editor’ option.
runneals
Forum|alt.badge.img+32
  • Mar 19, 2026 3:53 PM UTC
​@zoe.forbes Had a client that this just popped up in that’s running Flow 2024.2.3.
  1. We stopped the existing automation in production
  2. We imported a project with the automation and workspaces
  3. When we opened up the automation, the majority of the workspaces pulled in the workspace default not the global parameter, while a few somehow managed to keep their global parameters. Most of the global parameters we were using were for sde connections. Our non-connection parameters weren’t reset, so I wonder if it’s caused by the connections not existing in the other environment?
zoe.forbes
Forum|alt.badge.img+11
  • Mar 25, 2026 10:48 PM UTC
Thanks ​@_jacques_ and ​@runneals - I’ll add these cases to our internal notes.
