Automation and Engine Log Files - How long are they saved?
  • Apr 11, 2024 6:10 PM UTC
  • 90 views
vxn43
Forum|alt.badge.img+20
How long in terms of days is a log file saved after an Automation is run? is the log file overwritten the next time the same Automation runs? or is the log file archived somewhere?
Also, the log files in Resources referenced below, how long are they saved? how often are new ones created and saved?
Files & Connections - Resources - Logs - Engine - Old
Files & Connections - Resources - Logs - Core - Old
Best answer by j.botterill
Take a look at the System Cleanup section of the admin. There will be built in rules that clean up logs. I typically set the current job logs to 6-8 weeks, before they move to old. From memory there should be an automation logs settting
j.botterill
Forum|alt.badge.img+69
  • Apr 12, 2024 11:41 AM UTC
