Async Job Submitter Service
  • Sep 24, 2014 3:57 AM UTC
  • 58 views
Hello,
I have published a wrokflow as Job Submitter Service and I am sending a service request with service mode as ASYNC. I get immidiate response that job submitted successfuly. I am not sure how should I capture the response from the actual execution of service whether it's successful or failed. Is the notification service is only solution?
Best answer by david_r
your answer from the JobSubmitter will contain a JobID, which you can use to poll the job status:
http://myserver/transformations/jobs/id/<jobid>
Also look at the API documentation where this call is explained in detail:
http://docs.safe.com/fme/html/FME_REST/#
David
  • Sep 24, 2014 8:34 AM UTC
David
  • Sep 24, 2014 11:40 AM UTC
Thanks David.
