Arcpy script not working in fme flow
  • Jun 11, 2026 11:13 AM UTC
  • 7 replies
  • 81 views
chitra
I have an ArcPy script that works in FME Form but not in FME Flow. Can anyone help me resolve this issue?
  • Jun 11, 2026 11:15 AM UTC
Some more details would be helpful… Any error messages?
chitra
  • Jun 11, 2026 11:18 AM UTC
am getting this error
  • Jun 11, 2026 11:29 AM UTC
Looks like either the batch file or the Python scripts fails, for whatever reason. Unfortunately it’s not possible to say why without knowing the contents.
Are you sure that the path to the .bat and .py files exists on your Flow instance, and that the Flow service account has the appropriate permissions on those folders?
chitra
  • Jun 11, 2026 11:46 AM UTC
@echo Run
"C:\apps\ArcGIS\bin\Python\Scripts\propy.bat" D:\FME\resources\scripts\REFACTOR\Point_Removal_Code.py
@echo Finished
 This is my batch file. All the Python scripts in this location are available and working fine. Only the ArcPy script is having an issue. That’s why I’m unsure whether FME Flow can properly access ArcPy.
j.botterill
Forum|alt.badge.img+69
  • Jun 11, 2026 12:36 PM UTC
Exit code 1 from a batch in FME Form essentially means “the command failed”, so the key is why ArcPy (via propy.bat) is failing, not FME itself.
Does the ArcPy run in arcgis python interpreter?
propy.bat relies on ArcGIS Pro’s conda environment. Add the CALL to force full activation of ArcPRO python environment
@echo Run
CALL "C:\apps\ArcGIS\bin\Python\Scripts\propy.bat" "D:\FME\resources\scripts\REFACTOR\Point_Removal_Code.py"
@echo Finished
chitra
  • Jun 11, 2026 12:48 PM UTC
after trying this i didn’t get exit code 1 error but amm getting this error -----Run started at Thu 06/11/2026  5:46:11.89
Traceback (most recent call last):
  File "D:\FME\resources\scripts\REFACTOR\Point_Removal_Code.py", line 1, in <module>
    import arcpy
  File "C:\apps\ArcGIS\Resources\ArcPy\arcpy\__init__.py", line 77, in <module>
    from arcpy.geoprocessing import gp
  File "C:\apps\ArcGIS\Resources\ArcPy\arcpy\geoprocessing\__init__.py", line 14, in <module>
    from ._base import *
  File "C:\apps\ArcGIS\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 14, in <module>
    import arcgisscripting
  File "C:\apps\ArcGIS\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgisscripting\__init__.py", line 131, in <module>
    from ._arcgisscripting import *
RuntimeError: The Product License has not been initialized.
Finished at Thu 06/11/2026  5:46:20.81
  • Jun 11, 2026 1:06 PM UTC
Could it be that ArcGIS hasn’t been licensed and/or activated for the Flow service account?
