I was able to insert 847k records out of 1.6M last Friday then it just failed (token was refreshed). This morning, I've disabled / re -enabled versioning in ArcPro and was able to insert 600+ new records using FME. Tried another 600+ and failed with the below error.
ArcGIS Portal Feature Service Writer: Encountered an unexpected error. The error code from the server was '400' and the message was: 'Unable to complete operation.'. Details: 'Insufficient permissions [42000:[Microsoft][ODBC Driver 17 for SQL Server][SQL Server]The EXECUTE permission was denied on the object 'i24_get_ids', database 'CORPGIS', schema 'gisadmin'.] [Prod_Address]'
ARCGISPORTALFEATURES writer: A fatal error has occurred. Check the logfile above for details
P.S.
I have tried adding new records using ArcPro thru the same feature service and works fine. it only fails in FME even if I try to insert only 1 record.
Thanks in advance
