Writing attributes to AutoCAD User Properties
anamanvil
Hi All,
I am trying to write attributes to AutoCAD User Properties (within the panel) instead of exposing them using XDLIST Command.
Capture
I know how to do so manually in AutoCAD by using ADEDEFDATA Command and FME seems to be able to read these attributes, amend them or even add new ones and Write an AutoCAD File showing these attributes within the User Properties panel. However, it does not seem possible to write a new AutoCAD File with these properties or use a template with this table added to it.
Is this functionality even possible with FME? Have any of you found any alternatives?
Many thanks for the time,
Ana
Best answer by nielsgerrits
Thanks @nielsgerrits​, that is the writer I am using. However, what do you mind by Insertion Scale Units? I am not looking at units but at attribute values such as an Attribute Table in SHP for examples. These attributes can be access by using XDLIST command but I would like to add them to the User Properties panel as indicated by the red arrow on the above screenshot.
Hopefully this makes sense.
Here you go :)
nielsgerrits
Forum|alt.badge.img+67
You can write ObjectData with the "Autodesk AutoCAD Map 3D Object Data" writer.
You can't set the Insertion Scale Units like you can in the "Autodesk AutoCAD RealDWG DWG/DXF" but if you use a dwg template with the correct units it works fine.
anamanvil
  • September 22, 2021
nielsgerrits
Don't worry about the insertion scale units. Just use the "Autodesk AutoCAD Map 3D Object Data" writer, add the attributes you want to add to the User Attributes in the Writer and you will get the Object Data in the cadfile.
anamanvil
CaptureI've added the User Attributes; however, these attributes are not reflected as User Properties in the panel as per above picture. The only way to access them is by XDLIST command in AutoCAD. This is using the "Autodesk AutoCAD Map 3D Object Data" writer.
nielsgerrits
What version do you use? I checked in 2019 and 2021 and it just works fine?
2021-09-22_19h00_002021-09-22_19h01_28
anamanvil
I am using 2019, I am able to add them in the writer as per your screenshot. The problem I have is that I want them to be displayed within the User Properties (which is different to User Attributes in FME) in AutoCAD. At the moment, I can only visualize the attribution in AutoCAD File (not in FME) by running XDLIST Command... nothing is shown in the User Properties.
nielsgerrits
I really don't get what you are looking for. To be sure, do you need the result in this screenshot or something else? The OD:Output part.
2021-09-22_19h10_30
anamanvil
Yes that is right. Would you mind sharing your workspace with me as I am not able to achieve it? It would allow me to know the exact parameters you're using.
nielsgerrits
Here you go :)
anamanvil
Amazing! Thank you so much for your help! :)
nielsgerrits
Happy I could help :)
hannahwh05
Forum|alt.badge.img+10
Could you please re-share your workspace @nielsgerrits ? Since the website update, I can’t see it? I used to have this working on one of my workbenches but it’s stopped working
nielsgerrits
Sure.
hannahwh05
@nielsgerrits what a star! Thank you!
