Workspace tries to run on FME Cloud, but repo doesn't exist?
  • Apr 4, 2018 2:06 AM UTC
  • 52 views
cwarren
I have FME Cloud setup to run a workspace when it receives an e-mail. The workspace was previously in another repository that is now deleted, but still tries to run the deleted one as well as the current one. I have rebooted the server but have not been able to figure out why the workspace that no longer exists is trying to run.
The workspace in the current repo will run successfully, but it will also try to run the deleted workspace as well.
statusMessage
File Field Data Processing/FileNameValidation/FileNameValidation.fmw could not be opened
Best answer by takashi
Hi @madwarren, look at the Notifications > Subscriptions page in the FME Server Web UI and check if the subscriber which tries to run the deleted workspace have been removed.
  • Apr 4, 2018 2:38 AM UTC
cwarren
  • Apr 4, 2018 5:46 PM UTC
I knew it would be an easy fix! Thank you so much.
