Workspace runner and versioned spatial tables
  • Oct 2, 2017 2:50 PM UTC
  • 88 views
  • I am running a workbench to validate overlapping polygons
  • My table structure is versioned spatial tables
  • I have ran the validation workbench against one version, using a published parameter setting the override version. This has been successful for a single version.
  • I want to automate validating a large number of table versions.
  • I have attempted to use the workspace runner to achieve this. In order to change the override version. With the idea that this will run for each table version.
  • I have a tried using a CSV list of the versions and I have tried reading directly from the Oracle version table list.
  • I have been unable to produce an output with test cases, these test cases produce an output when run against an individual version.
  • I think the workspace runner is failing to change the override version published parameter instead running against the SDE.default version for the same amount of versions within the CSV list.
I would be greatful for any help or advice, at a bit of a loss.
Thanks, Scott
Best answer by markatsafe
It looks like there is an arcpy function that returns a list of versions: http://pro.arcgis.com/en/pro-app/arcpy/functions/listversions.htm. Could you use PythonCaller to get the list of versions and then pass that to your validation workspace through the WorkspaceRunner instead of using a static CSV file? If you can't get the Geodb (ArcSDE reader) to accept the new version, perhaps the FeatureReader would work
rylanatsafe
Forum|alt.badge.img+14
@sw667 - Hi Scott, do you have a workspace (.fmw) that you can share with us?
Reading your summary, I think you had a great idea to use a CSV list of the versions. Perhaps it needs to be coupled with a loop (implemented with a Custom Transformer).
*It will also help if you can share that simple CSV file.
  • Oct 4, 2017 5:14 PM UTC
  • Oct 10, 2017 7:59 AM UTC
@RylanAtSafe @MarkAtSafe Thank you both for your advice, I tried all of your suggestions and it was the FeatureReader that was successful in reading each of the versions from SDE.
