Workbench finishes in 12.9 seconds in Desktop but never ends in Server,
  • Feb 15, 2014 10:11 AM UTC
  • 59 views
jamal
Forum|alt.badge.img+5
For the same data source, the workbench finishes in 12.9 seconds in Desktop but when the same workbench is run from the FME Serve with same data source it never ends
What might be the issue here?
Thank you
Best
Jamal
  • Feb 17, 2014 7:34 AM UTC
Hi Jamal,
Check the logfile. There you should find the answer. You can find the logfile on your server <FMEServerDir>\\Logs\\jobsubmitterservice\\FME_job_<nr>.log
Thomas
jamal
  • Feb 26, 2014 8:42 PM UTC
thanks Thomas
best
Jamal
