wind direction route
  • Mar 22, 2019 1:18 PM UTC
  • 5 replies
  • 64 views
jan_van_prooije
Hello,
As a hobby i'm a cyclist and i was wondering how to set up a workspace which can calculate how much percent of the time the wind is in favor of the cyclist.
If the wind is blowing from the north west (arrow) i would like to know how much percent of the time i have the wind in my back en i have the wind against me. What would be the transformer to get the wind direction into my route data?
gio
Forum|alt.badge.img+15
  • Mar 22, 2019 2:38 PM UTC
In your pic you have one windirection arrow.If you want to add it to the route, you can just unconditionally merge it.
Unconditional FetureMerging is when you have mergkeys both are constant and equal.
Mostly is use 1=1.
Now you can use an expression tot calculate direction difference between the cyclist and the wind.
Azimuth calculator on all lines (route chopped to 2vertice pieces) and
You probably know better which range of difference would be in favour or not. Difference of 90-270 degree is not favourable I presume.
If you have more wind directions on route you need to merge them by zoning/segmenting the route and create groups prior to merging (so you can merge by group).
Forum|alt.badge.img+63
On a side note, there is an API available from one of the major Dutch weather data providers (Weerslag), I don't know how public it is but could find out for you. I'm pretty sure it can give you wind direction in multiple locations (and times!) along your route so you can process that as @gio suggests.
Forum|alt.badge.img+54
  • Mar 22, 2019 9:58 PM UTC
Just for a little bit of python practice on a Friday night, a wind angle of 135 is blowing from the north west, 180 from the north etc. Anything in the same direction, plus or minus 90 is favourable
wind.fmw
jan_van_prooije
wind.fmw
Thanks a lot!
  • Mar 23, 2019 2:55 PM UTC
Thanks a lot!
And if you don't want to use python
wind_2.fmw
