Why do I need to reauthenticate Dropbox web connection everytime?
jaygrg111_
I have configured all parameters on manage web services for Dropbox. But I am having to reauthenticate every time I run the workspace. What should I be checking? I also need to schedule it on Server. I am not being able to authorize it on Server as well. Any feedback is highly appreciated.
danilo_fme
Forum|alt.badge.img+42
  • February 21, 2024
Hi @jaygrg111_
What is the version of FME do you have?
Thanks in Advance,
Danilo
jaygrg111_
  • February 21, 2024
Hi @danilo_fme Its version FME2022.2
Thank you
milo89
Forum|alt.badge.img+16
  • March 19, 2025
Hi ​@jaygrg111_,
Did you end up finding a solution to this one? I’ve been experiencing the same issue (FME 2025) and it seems like it lasts less than 12 hours when being utilised on FME Flow.
Thanks
milo89
  • March 20, 2025
Hi ​@jaygrg111_,
After digging around a little bit, it’s actually referenced in the Automating Dropbox Workflows article that:
The Automation is failing with an invalid token
If your automation is occasionally failing due to an invalid token from Dropbox, this is due to Dropbox's OAuth 2.0 Authentication Service generating temporary tokens which last four hours before requiring a reset. There is currently no resolution for FME Flow, please see the Known Issues page for more information on FME Form.
The Dropbox trigger in automations is set up differently so doesn’t fail as fast as the web connection.
