Which transformers to use to work with different geometry?
  • Apr 19, 2024 2:26 PM UTC
  • 0 replies
  • 97 views
marias
Forum|alt.badge.img+11
Hello,
Could you advice, please, what transformers to use for my task? This might be easy task, but I am stuck. :(
What I have: generic reader with the dataset in any of these formats SHP, TAB, KML or CSV.
I need to define:
  • if there is no geometry, WKT or SRID then set corresponding attributes to NULL
  • If there is binary geometry then put the geometry to the attribute YY
  • If there is WKT then add WKT value to the attribute UU
  • if there is also a SRID in the file put that in ...
How to check if my data has "no geometry", binary geometry, WKT and SRID and set conditions?
Appreciate your help. Thank you in advance.
