Where is the "recover" file if Form crashed before it's named and saved?
  • Sep 13, 2024 4:59 PM UTC
  • 657 views
tnarladni
Forum|alt.badge.img+24
I remember back in 2021 when this happened, someone from Safe was able to point me to where the “recover” file was saved. Please help me again as i have created a very robust workspace but have not saved it and it would take me 3 hrs to recreate this workspace
Best answer by debbiatsafe
Hello @tnarladni
By default, recovery files are saved in the location specified in a user’s TEMP environment variable on Windows--usually %appdata%\AppData\Local\Temp\. If FME_TEMP is set, you can also look in that folder.
Look for any files beginning "wb", especially “wb-xlate” and “wb_recov”. Change the file extension to .fmw and try opening in Workbench.
I hope this information helps.
debbiatsafe
  • Sep 13, 2024 10:37 PM UTC
Hello @tnarladni
ctredinnick
Forum|alt.badge.img+22
  • Sep 14, 2024 11:09 PM UTC
The “.recover” file is just a text file, you can edit it in notepad to see the folder where the wb backup is saved to. But if the workbench was never saved, I’m not sure if you’ll have a recover.
Forum|alt.badge.img+63
Somebody once taught me the “cool-save” rule: as soon as you think “cool” hit save. Make it a Pavlovian reaction to hit ctrl-s
