Where (folder location) does FME store database connections?
  • October 15, 2019
  • 352 views
nicholas
Forum|alt.badge.img+14
My work colleague is trying and failing to connect to Oracle Spatial.
I suspect that her installation of FME is slightly broken and she lacks the access rights to the folder where FME connections are stored.
When she goes to Tools | FME Options | Database Connections FME pops up an error message "Unable to retrieve database connections"
And she is also unable to create a new database connection.
If I knew the folder location, we could check if she has the proper access rights assigned by IT.
Thanks,
Nick
Best answer by david_r
On Windows it should be in
%APPDATA%\Safe Software\FME\fme_connections.data
  • October 15, 2019
sigbono
Forum|alt.badge.img+11
  • February 12, 2024
This is also happening to me when upgrading from one beta version to another. I needed to delete the contents of this folder and I was now able to save database connection. Is there a way to import the old connections though?
