Where Clause- for two feature types.
  • May 27, 2020 8:19 PM UTC
  • 36 views
seasonishere_20
I am trying to get two feature types at a time. I am not getting any errors, rather the translation is successful but not getting any output table. Also, I am not getting the "Translation Parameter Values" where I can mention both the user parameter. By clicking Run, it is just directly Running the workspace. @markatsafe @nampreetatsafe
  • May 28, 2020 7:10 AM UTC
Do both tables contain the attributes SessionName and username? Also be careful about case sensitivity for both these values.
If you want to be prompted for published parameters each time the workspace is run, you can active this option under the menu Run / Prompt for User Parameters:
