What published parameters are supported in FME Data Experss App?
  • May 7, 2020 4:31 PM UTC
  • 116 views
I've been looking for some documentation on FME Data Express with no luck. Specifically I'm looking for what published parameters are supported by Data Express.
Some of my published parameters in a workspace has the label [unsupported] added to them when I open the workspace in Data Express.
It would be great help to know which types of published parameters are supported.
Best answer by siennaatsafe
Hi @danielhamngren,
We are still working on our documentation. However, here is a list of all published parameters supported. Please let me know if you have any questions.
As of v 1.3.2, the following published parameters are supported in the app:
  • Workbench 2020 types:
    • Attribute List (comma delimited)
    • Attribute List (ordered)
    • Attribute List (space delimited)
    • Attribute Name
    • Coordinate System Name
    • Filename (Existing)
    • Password - app does not support “default” password values
    • Text
    • Text (Multiline)
    • Text (Multiline) Or Number
    • URL
    • Date
    • Date/Time - app does not support setting “seconds & milliseconds” yet
    • Filename (Multiple)
    • Choice (Multiple)
    • Choice with Alias (Multiple)
    • Web Connection
    • Number
    • Choice
    • Choice or Text
    • Choice with Alias
  • Special parameter types:
    • QR code - via “Text” type published parameter
    • Barcode - via “Text” type published parameter
    • Location - via “Text” type
      • to use this parameter type, prefix the name of the parameter with “FMEEXPRESS_LOCATION_”
  • These older parameter types have been known to work. However, they are being deprecated:
    • INTEGER
    • INT
    • FLOAT
    • STRING
    • FILEMUSTEXIST
    • CHOICE_OR_TEXT
    • FLOAT_OR_CHOICE
    • INT_OR_CHOICE
    • MULTICHOICE
    • FILE_OR_URL
    • DATE_TIME
siennaatsafe
Forum|alt.badge.img+12
  • May 8, 2020 6:20 PM UTC
Hi @danielhamngren,
    • Attribute Name
    • Text
    • Text (Multiline)
    • URL
    • Date
    • Choice (Multiple)
    • Web Connection
    • Number
    • Choice
    • Choice or Text
    • Choice with Alias
    • INTEGER
    • INT
    • FLOAT
    • STRING
    • FILEMUSTEXIST
    • CHOICE_OR_TEXT
    • FLOAT_OR_CHOICE
    • INT_OR_CHOICE
    • MULTICHOICE
    • FILE_OR_URL
    • DATE_TIME
Hi @danielhamngren,
    • Attribute Name
    • Text
    • Text (Multiline)
    • URL
    • Date
    • Choice (Multiple)
    • Web Connection
    • Number
    • Choice
    • Choice or Text
    • Choice with Alias
    • INTEGER
    • INT
    • FLOAT
    • STRING
    • FILEMUSTEXIST
    • CHOICE_OR_TEXT
    • FLOAT_OR_CHOICE
    • INT_OR_CHOICE
    • MULTICHOICE
    • FILE_OR_URL
    • DATE_TIME
Thank you! This was exactly what I was looking for.
/Daniel
