Warning: not all FMESessions that were created were destroyed before shutdown. This may cause instability
  • Nov 22, 2012 3:31 AM UTC
  • 186 views
??Windows?????????:               fme.exe wb-xlate-1353554731187_5952           --SourceDataset_MapGis6x """""C:\\Documents and Settings\\Administrator\\My Documents\\1.WT"" ""C:\\Documents and Settings\\Administrator\\My Documents\\1.WP"""""           --DestDataset_MapGis6x "C:\\Documents and Settings\\Administrator\\My Documents"           ???? ... Feature Manipulation Engine 2012 SP2 (20120417 - Build 12238 - WIN32) FME_HOME is 'C:\\Program Files\\FME\\' FME Desktop Professional Edition (floating) Permanent License. Machine host name is: fangjun START - ProcessID: 904, peak process memory usage: 26024 kB, current process memory usage: 26020 kB FME Configuration: Command line arguments are `C:\\Program Files\\FME\\fme.exe' `C:\\DOCUME~1\\ADMINI~1\\LOCALS~1\\Temp\\wb-xlate-1353554731187_5952' `LOG_STANDARDOUT' `YES' `LogCount' `C:\\DOCUME~1\\ADMINI~1\\LOCALS~1\\Temp\\wb-xlate-counts-1353554731187_5952' Shared directories for formats are : C:\\Documents and Settings\\Administrator\\My Documents\\FME\\Formats;C:\\Program Files\\FME\\datasources Shared directories for transformers are : C:\\Documents and Settings\\Administrator\\My Documents\\FME\\Transformers;C:\\Program Files\\FME\\transformers Shared directories for coordinate systems are : C:\\Documents and Settings\\Administrator\\My Documents\\FME\\CoordinateSystems Shared directories for coordinate system exceptions are : C:\\Documents and Settings\\Administrator\\My Documents\\FME\\CoordinateSystemExceptions Shared directories for transformer categories are : C:\\Documents and Settings\\Administrator\\My Documents\\FME\\TransformerCategories FME Configuration: Reader Keyword is `MapGis6x_1' FME Configuration: Writer Keyword is `MapGis6x_2' FME Configuration: Writer Group Definition Keyword is `MapGis6x_2_DEF' FME Configuration: Reader type is `MAPGIS6X' FME Configuration: Writer type is `MAPGIS6X' FME Configuration: No destination coordinate system set FME Configuration: Geometry Handling Mode is `Enhanced'  FME Configuration: Current working directory is `C:\\Documents and Settings\\Administrator\\Local Settings\\Temp' FME Configuration: Temporary directory is `C:\\DOCUME~1\\ADMINI~1\\LOCALS~1\\Temp' FME Configuration: FME_HOME is `C:\\Program Files\\FME\\' FME Configuration: FME_BASE is 'no' FME Configuration: FME_MF_DIR is 'C:\\DOCUME~1\\ADMINI~1\\LOCALS~1\\Temp/' FME Configuration: FME_MF_NAME is 'wb-xlate-1353554731187_5952' FME Configuration: FME_PRODUCT_NAME is 'FME(R) 2012 SP2' System Status: 2596MB of disk space available in the FME temporary directory (C:\\DOCUME~1\\ADMINI~1\\LOCALS~1\\Temp\\) System Status: 1929MB of virtual memory available Operating System: Microsoft Windows XP Professional Service Pack 3 (Build 2600) FME Platform: WIN32 Locale: zh_CN Code Page: 936   (ANSI/OEM - ???? GBK) FME Configuration: Process limit is 2038 MB (out of 2038 MB physical memory and 2047 MB address space) FME Configuration: Start freeing memory when process usage exceeds 847 MB of memory or 1447 MB of address space FME Configuration: Stop freeing memory when process usage is below 635 MB of memory and 1085 MB of address space FME Configuration: Autodetermining optimal maximum number of objects in memory Trying to find a BUILTIN plugin for writer named `MAPGIS6X' Trying to find a DYNAMIC plugin for writer named `MAPGIS6X' Loaded module 'MAPGIS6X' from file 'C:\\Program Files\\FME\\plugins/MAPGIS6X.dll' FME API version of module 'MAPGIS6X' is '3.6 20090807', which is older than the current with FME internal API version '3.7 20111219'.  An updated plug-in may be available from the provider. MapGis6x plugin version is 1.0.0.0 For more information, please visit 'http://blog.sina.com.cn/u/2097001694' or mail to 'myfmedev@gmail.com'. Thank you for using MyFME products FME Configuration: Reading 2 dataset(s) with MapGis6x reader identified by MapGis6x_1 MULTI_READER(MapGis6x_1): Will continue past member reader failures MULTI_READER(MapGis6x_1): Adding MAPGIS6X Reader with keyword MapGis6x_1 Using Multi Reader $Revision: 83969 $ ( $Date: 2011-11-17 18:21:59 -0800 (Thu, 17 Nov 2011) $ ) with keyword `MapGis6x_1' to read multiple datasets Trying to find a BUILTIN plugin for reader named `MAPGIS6X' Trying to find a DYNAMIC plugin for reader named `MAPGIS6X' FME API version of module 'MAPGIS6X' is '3.6 20090807', which is older than the current with FME internal API version '3.7 20111219'.  An updated plug-in may be available from the provider. MapGis6x plugin version is 1.0.0.0 For more information, please visit 'http://blog.sina.com.cn/u/2097001694' or mail to 'myfmedev@gmail.com'. Thank you for using MyFME products Opened MapGis File 'C:\\Documents and Settings\\Administrator\\My Documents\\1.WT' for input Unknown coordinate system, paras: 'Datum[1], Projection[0], Unit[0], Longitude[0.000000], Longitude1[0.000000], Longitude2[0.000000], Latitude[0.000000], Latitude1[0.000000], Latitude2[0.000000], Dx[0.000000], Dy[0.000000]', MapGis file 'C:\\Documents and Settings\\Administrator\\My Documents\\1.WT' FME API version of module 'MAPGIS6X' is '3.6 20090807', which is older than the current with FME internal API version '3.7 20111219'.  An updated plug-in may be available from the provider. MapGis6x plugin version is 1.0.0.0 For more information, please visit 'http://blog.sina.com.cn/u/2097001694' or mail to 'myfmedev@gmail.com'. Thank you for using MyFME products FME API version of module 'MAPGIS6X' is '3.6 20090807', which is older than the current with FME internal API version '3.7 20111219'.  An updated plug-in may be available from the provider. MapGis6x plugin version is 1.0.0.0 For more information, please visit 'http://blog.sina.com.cn/u/2097001694' or mail to 'myfmedev@gmail.com'. Thank you for using MyFME products Loaded module 'LogCount_func' from file 'C:\\Program Files\\FME\\plugins/LogCount_func.dll' FME API version of module 'LogCount_func' matches current internal version (3.7 20111219) PointOnAreaOverlayer(OverlayFactory): Overlaying points on areas Trying to find a BUILTIN plugin for reader named `MAPGIS6X' Trying to find a DYNAMIC plugin for reader named `MAPGIS6X' FME API version of module 'MAPGIS6X' is '3.6 20090807', which is older than the current with FME internal API version '3.7 20111219'.  An updated plug-in may be available from the provider. MapGis6x plugin version is 1.0.0.0 For more information, please visit 'http://blog.sina.com.cn/u/2097001694' or mail to 'myfmedev@gmail.com'. Thank you for using MyFME products Opened MapGis File 'C:\\Documents and Settings\\Administrator\\My Documents\\1.WP' for input Unknown coordinate system, paras: 'Datum[1], Projection[0], Unit[0], Longitude[0.000000], Longitude1[0.000000], Longitude2[0.000000], Latitude[0.000000], Latitude1[0.000000], Latitude2[0.000000], Dx[0.000000], Dy[0.000000]', MapGis file 'C:\\Documents and Settings\\Administrator\\My Documents\\1.WP' MULTI_READER(MapGis6x_1): Done reading 13 features from 2 readers Emptying factory pipeline Unexpected Input Remover(TestFactory): Tested 13 input feature(s) -- 13 feature(s) passed and 0 feature(s) failed Unexpected Input Remover Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s) Source -> Generic(TeeFactory): Cloned 13 input feature(s) into 13 output feature(s) 1_WT Feature Counter -1 4(TeeFactory): Cloned 10 input feature(s) into 10 output feature(s) 1_WP Feature Counter -1 3(TeeFactory): Cloned 3 input feature(s) into 3 output feature(s) PointOnAreaOverlayer(OverlayFactory): Creating spatial index of 3 area features PointOnAreaOverlayer(OverlayFactory): Computing relationships between 3 input areas and 10 input points Warning: not all FMESessions that were created were destroyed before shutdown.  This may cause instability?somebody know why? thanks
sigtill
Forum|alt.badge.img+25
  • Nov 22, 2012 7:25 AM UTC
Not related to your specific question, however perhaps you could investigat to see if there is a new/old version of MapGis6x ? Some plugins are written to some versions of FME`s API (For instance FME2011 or FME2012) so there might be some small differences?
kathyross
Participant
Forum|alt.badge.img+9
  • Participant
  • Nov 22, 2012 11:39 PM UTC
When FME crashes and gives the error you received, it can be due to various problems. I'd recommend the following:
  • As Sig recommended, try another version of FME Desktop if you have one. I currently have FME 2010, 2011, 2012 and 2013 beta. Have found that older versions sometimes work better in rare cases
  • Check the RAM usage via Task Manager at the time the workspace quits. You may have insufficient RAM
  • Check the amount of free HDD space on all of your drives at the time workspace quits. Tempporary files are written by FME and if the HDD runs out of space, FME can crash
  • Use the Feature Inspector to locate which feature is causing FME to crash. It may be unexpectedly large, invalid, etc.
Hope this helps!
