want to pass credential to FME workbench from C# window application .
  • Aug 18, 2017 7:41 PM UTC
  • 55 views
fmelizard
Forum|alt.badge.img+22
  • Aug 18, 2017 7:42 PM UTC
Hello @rajibtechlabs. Welcome to the FME Knowledge Center community! Sharing a few more details will help the FME community help you. Please reply to this thread and provide additional details including:
  • The version of FME you are using, including build number and edition
  • A small sample of your data, or screenshots of the data in the FME Data Inspector
  • A description of your expected output, with screenshots if possible
  • Your FME workspace
  • Your FME translation log file
  • Any other information that may be useful to share
danilo_fme
Forum|alt.badge.img+58
  • Aug 19, 2017 4:00 PM UTC
Interesting question @rajibtechlabs
stalknecht
  • Aug 23, 2017 6:14 AM UTC
Workbench uses the credentials from the current user. Sure you can impersonate another user in C#. You could also look at fmeobjects how to start a workspace. The question is what are you trying to achieve? If you want to access resources from workbench then you can use published parameters to pass the credentials.
