Using FME server parameters on the desktop
  • Oct 7, 2019 8:35 AM UTC
  • 8 replies
  • 420 views
arjanboogaart
Participant
I'm working on a script that I downloaded from the server and want to run this on the desktop version.
It requires a couple parameter changes to make that working, but it's quite a hassle to do that properly whenever switching between desktop and server.
For instances changing the featureReader file path from $(FME_SHAREDRESOURCE_TEMP)/$(FME_MF_NAME)/foo.json to ~/documents/FME/foo.json
I noticed that I can set FME server parameters on the desktop, which are currently all empty.
Can I for example set $(FME_SHAREDRESOURCE_TEMP) = ~/documents and $(FME_MF_NAME) = FME so it works on the desktop and server without the need to change these parameters whenever I switch between server and desktop?
arjanboogaart
Participant
  • Participant
  • Oct 7, 2019 8:47 AM UTC
It didn't quite do what I expected. First, $(FME_MF_NAME) cannot be set manually.
So I set $(FME_SHAREDRESOURCE_TEMP) = ~/documents/FME.
However, it reads this as relative path, so it created the folders from the location of the script: ~/documents/FME/~/documents/FME/$(FME_MF_NAME)/
Setting $(FME_SHAREDRESOURCE_TEMP) = output fixes it, creating the output files in ~/documents/FME/output/$(FME_MF_NAME)/
  • Oct 7, 2019 8:53 AM UTC
As you've discovered, you cannot set FME_MF_NAME, it will always correspond to the workspace name.
For the FME Server parameters, you can override them in FME Desktop and point them to a local path. When you execute the workspace on FME Server the "local overrides" are automatically overwritten by the server values.
All paths in FME are interpreted as relative to the workspace file, as far as possible. This is to make it easier to move workspaces and associated files between systems.
arjanboogaart
Participant
  • Participant
  • Oct 7, 2019 10:06 AM UTC
Ah, that is really nice. I couldn't find any documentation on how they can be used on the desktop version.
This'll save me quite a lot of time
mattwilkie
Forum|alt.badge.img+11
  • Jun 23, 2022 10:54 PM UTC
can you flesh this out with an example please? When I set a parameter to "$(FME_SHAREDRESOURCE_TEMP)" in desktop CSV2 Writer after closing the dialog it goes blank and the script fails when running.
  • Jun 27, 2022 9:16 AM UTC
Did you define the value of FME_SHAREDRESOURCE_TEMP in the Workspace Navigator first?
mattwilkie
  • Jun 27, 2022 3:56 PM UTC
No I hadn't done that. Thanks!
arnovananrooij
Forum|alt.badge.img+5
@david_r​ Is there a way of setting this value for all workspaces run from Desktop? Now I need to set this over and over for each workspace.
  • Nov 3, 2022 4:20 PM UTC
Not that I know of, unfortunately.
