User Parameters Feature Types to Read:
  • Aug 20, 2013 4:55 PM UTC
  • 38 views
jhawks
Forum|alt.badge.img+7
I knew how to do this, now I can't find it. How to publish features types to read, so that they'll be availble in a public fme server workbench?
fmelizard
Forum|alt.badge.img+22
  • Aug 20, 2013 5:59 PM UTC
This is usually found in the reader>advanced>feature types to read.
From there you can right click it and publish.
Hope this helps,
Itay
  • Aug 21, 2013 4:22 AM UTC
You already found "Feature Types to Read" node on the Navigator window.
To the next, try these steps as Itay suggested.
1) Right-click on "Feature Types to Read" to open the short cut menu.
2) Select "Create User Parameter" item in the menu.
  Takashi
fmelizard
  • Aug 21, 2013 6:50 AM UTC
In your image the source dataset (SDE) is published and therefore not green anymore, after publishing the feature types to read it should also change colour and become available when prompting.
Itay
