User Parameter value is invalid if ending in a backslash
  • Aug 8, 2017 9:57 PM UTC
  • 6 replies
  • 83 views
If a User Parameter ends in a backslash - such as a Windows path, then accessing that value in a PythonCaller results in extra text. Example: if a User Parameter called foldername has the value:
frog\\
then using fme.macroValues['foldername'] or FME_MacroValues['foldername'] in a PythonCaller returns:
frog GUI OPTIONAL TEXT foldername Folder name:
jneujens
  • Aug 9, 2017 7:41 AM UTC
I got the same issue. It just changes to the 'frog\\' to that whole string. I am curious about the how and why?
trentatsafe
Forum|alt.badge.img+7
Hello @rsliva and @jneujens
Are you able to provide us with a few more details:
What is the User parameter definition?
Along with the PythonCaller code, you are running to see the results. This appears to be a possible bug and as such, I would file a PR once I verify the behaviour.
jneujens
  • Aug 9, 2017 7:59 AM UTC
parameter-backslash.fmw
This is my example workspace, just something really quick to check @rsliva's question.
trentatsafe
Thank you for the workspace. I will file a PR for this and try to get some feedback regarding this.
trentatsafe
I have found an existing PR pertaining to this, I have attached this posting to the PR, so that if any updates occur regarding a possible fix this question will be updated.
In the meantime, if dealing with a string that ends with a \\, it may be best to try another Parameter type such as 'Folder' or 'File Name'.
I hope this helps.
  • May 7, 2021 8:58 AM UTC
I just stumbled upon this old thread, I'll just add the following for those that are still affected by this issue.
Rather than writing:
You can write the following, which should prevent FME from interfering with your code:
fme.macroValues.get('foldername')
