Upload files to resource folders using Rest API. I am getting 415 HTTP error. Below is my python code.
  • Sep 14, 2021 8:33 PM UTC
  • 252 views
suresh_nalla
import os
import requests
import json
import cv2
directory = r'C:\\boatlaunch'
for filename in os.listdir(directory):
 if filename.endswith(".jpg") or filename.endswith(".jpge") or filename.endswith(".JPG"):
  print(os.path.join(directory, filename))
  filenamepath=os.path.join(directory, filename)
  url = "https://<servername>/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/filesys/EnvironmentAffair?createDirectories=false&overwrite=false"
  head={
   'Authorization': 'fmetoken token=<mytoken>',
   'Content-Disposition': 'attachment; filename="test.jpg"',
   'Content-Type': 'application/octect-stream',
   'Accept': 'application/json'
  print(head)
  filedata = open(filenamepath,'rb')
  print(filedata)
  res = requests.post(url,data=filedata,headers=head)
  print(res.status_code)
  print(res.text)
  print(res.request.headers)
Best answer by suresh_nalla
Below code works. I was trying to upload files from the local windows folder to FME server resource folder using FME REST API. I was having issue with header of the web api call. I got the solution.
import os
import requests
import json
apitoken = '<apitoken>'
fmeservername = '<yoursever>'
resourcefoldername = '<yourfoldername>'
directory = '<directorypathwherefilesstored>'
  url = "https://{0}/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/filesys/{1}?createDirectories=false&overwrite=true".format(fmeservername,resourcefoldername)
  head={
   'Authorization': 'fmetoken token={0}'.format(apitoken),
  myfile = {'file': open(filenamepath ,'rb')}
  res = requests.post(url, files = myfile, headers=head)
  #print(res.text)
  #print(res.request.headers)
Forum|alt.badge.img+63
HTTP error 415 is about unsupported media types. What exactly are you trying to do?
suresh_nalla
  • Sep 15, 2021 2:32 PM UTC
import os
import requests
import json
  head={
  #print(res.text)
