unattended install floating license FME2019
  • Feb 11, 2020 3:19 PM UTC
  • 31 views
Installed FME2019 unattended. When starting up, it asks for the floating license server. Where is that information stored in registry/files?
We have a non persistent VDI and next time I login, everything is gone.
  • Feb 11, 2020 3:35 PM UTC
To configure a floating license server, try the following from the command line:
<FME home>/fmelicensingassistant --floating <server>[:<port>] <FME Edition>
See also:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Admin_Guide/FMEInstallation/Licensing-Linux.htm (it says Linux but should work for Windows as well, AFAIK)
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Admin_Guide/FMEInstallation/Specifying_FME_Edition_to_Use.htm
