Two dynamic surfaces find volume cut fill calculation
  • Jul 19, 2024 2:39 AM UTC
  • 0 replies
  • 107 views
jp12212
Forum|alt.badge.img+4
Hi, I was hoping to create a workbench that has a base surface and a target surface and finds the volume between the two, is there any way to do that with the below transformer ie. make the base a surface with elevation differentials?
Any suggestions appreciated!
Thank you.
