To and From attributes in Line Feature
  • Jul 18, 2024 5:23 PM UTC
  • 48 views
fme_can_do_it
Forum|alt.badge.img+13
Hi, I'm trying to populate the "To" and "From" attributes in the Line feature. I have points snapped to the line feature, causing the line to split at the point. I need to fill out the "To" and "From" attributes. I tried a certain approach, but it didn't work:
I buffered the point feature and used LineOnAreaOverlayer, and then the Coordinate extractor to find the start and end points of the line.
If there is any other way I can use to accomplish this task, please advise.
Thanks!
liamfez
Forum|alt.badge.img+44
  • Jul 18, 2024 6:20 PM UTC
The TopologyBuilder may be the transformer you are looking for.
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/topologybuilder.htm
Or perhaps a SpatialRelator generating a list of intersecting features’ attributes, then you can create attributes from that list.
