The Workspace requires Python version %0, but Python version %1 is already loaded
  • Apr 3, 2018 12:00 AM UTC
  • 7 replies
  • 261 views
Good day.
I faced the problem with running jobs on FME-Server. Periodically (not always) jobs are crashed with status message: "The Workspace requires Python version %0, but Python version %1 is already loaded". I absolutely confused, because if I start this WB again the process will be completed successful.
ArcGIS and FME-Server installed on this machine together and as the custom python the Esri ArcGIS Desktop (Python 2.7) selected.
Who knows how to overcome this problem?
Thanks in advance.
  • Apr 3, 2018 8:12 AM UTC
Is it possible that you have a mix of workspaces using Python 2 and 3?
There's a known issue with FME Server when a workspace requests a different Python version than the previously used Python version on the same engine.
More details here (also consider voting for the idea to improve this): https://knowledge.safe.com/idea/36272/allow-different-fme-cloud-python-interpreter.html
  • Apr 4, 2018 12:35 AM UTC
Thank you for the answer.
Absolutely for all workbenches the Esri ArcGIS Desktop (Python 2.7) python version selected. This point is on special control because all of our workbenches work with ESRI databases and it required for compatible with data writing/reading.
With FME-Server 2015 we had no this problem.
I am facing the same identical issue and I can guarantee I double, triple, quadruple checked the "different Python version than the previously used Python version on the same engine"
tino
Forum|alt.badge.img+28
  • Feb 12, 2019 10:39 AM UTC
What FME Server version do you run?
This should be fixed in recent versions:
Yes, the Engine should know to try to reload the correct python interpreter when there is a mismatch like this. This issue that you're seeing is a problem that was present in some of the earlier versions of the FME Server 2018 betas and we have fixed this for 2018.0 (build 18310 and newer) as well as 2018.1 build 18481 and newer (from the log file, it looks like you're seeing this on build 18459). With the fix, when an engine encounters a python version mismatch like this, it will automatically restart the engine so that it can load up the correct interpreter.
So FME Server should be able to reload the appropriate interpreter.
If you are stuck with an older version, just change in fmeServerConfig.txt:
MAX_TRANSACTION_RESULT_SUCCESSES=100
MAX_TRANSACTION_RESULT_FAILURES=10
both to 1. This forces the engines to restart after every process. (It takes only a fraction of a second, so in most cases no speed regression should occur).
[*] https://docs.safe.com/fme/html/FME_Server_Documentation/Content/ReferenceManual/ConfigFileRef.htm
Hi @tino, thanks a lot for your help. Investigating the issue I realised we are actually running on the version problem. I ignored the fact we have a shared FME server and some of my colleagues are still running workbenches with 2.7 interpreter set. So here is the thing, if someone else uploads a workbench on server with 2.7 and happens to run on the engine where the following one has 3.4+ then the second one will break, so the issue isn't much with the workspace that breaks but with the one that ran previously, even if it is from a different user and a different process. I got it now.
  • Apr 9, 2019 11:50 PM UTC
The inability for FME Server - in my case 2018.1.1.2 - to switch between Python versions (2.7/3.4) as required suggests a bug (unless it's explicitly not supported and then it should not allow the publish/scheduling).
Should this bug not be logged and fixed?
Error:
helmoet
Forum|alt.badge.img+8
  • Feb 4, 2020 8:15 AM UTC
Hi, we also run into this (FME Server 2017.1.1). Not sure if upgrading is an option. The workspace I used that caused the error uses the JSON reader which apparently uses Python. Is there a possibility to force reloading Python in the workspace?
